I'm attempting to use Esri ArcGIS Portal Feature Service writer in FME 2017. I get the following error: The dataset '*******.*******.com\\portal' does not appear to be a valid domain. Verify that the dataset is a valid host. Records seems to pass along the connector to the writer but log file shows no features were written.
