Asking this on behalf of a customer:
They recently upgraded to FME 2019 and are having some issues writing to SDE. If they write to an existing feature class they get this:
Geodatabase Writer: The field 'OBJECTID' in table 'Afvalbakken' will not be updated since it is not editable
A 3D feature was encountered in the feature class 'Afvalbakken', which is defined as containing 2D features. The feature, and any other applicable features in the same feature class, will be modified so that it has the same dimension as the feature class
An error occurred while attempting to insert a row into the table 'Afvalbakken' using a cursor. The error number from ArcObjects is: '-2147418113'. The error message from ArcObjects is: {Klasse is niet geregistreerd
}Writing to a new feature class leads to
Transactions are being used by the Geodatabase Writer
GEODATABASE_SDE writer: An unknown exception occurredAny suggestions?
