Creating interactive PDFs with layer visibility
  • May 4, 2016
  • 6 replies
  • 68 views
Does anyone know if in FME it is possible to create a PDF with different layers (shapefiles) where you can switch off and on their visibility?
Forum|alt.badge.img+46
  • May 4, 2016
Yes, you can write geospatial pdfs to do this
There is an FME webinar that may be a useful starting point
how-to-share-spatial-data-with-anyone-anywhere-as-pdf
  • May 4, 2016
Yes it is possible. You can use the PDF2D-Writer, but i dont know if you could set different layers on/off while creating.
  • May 4, 2016
There is a layer visibility on open parameter that you can set to control what is displayed initially
  • May 4, 2016
This is not exactly what I want. I need to read a couple shapefiles into a PDF, where I can turn on and off their visility, as you would do in an ArcMap/QGIS workspace.
  • May 4, 2016
You can do this with a geospatial pdf
  • November 21, 2016
@darius
To create individual pdf layers for every input shapefiles, use AttributeCreator for every input shapefile and add the "fme_feature_type" attribute assigning a name for every layer as you want it to appear in a pdf.
Then make sure to use @Value(fme_feature_type) as a name of the output pdf in the pdf writer.
Hope that helps.
Magda
