I am using the Esri ArcGIS Online (AGOL) Feature Service writer and can connect to ArcGIS Online and see existing feature services. However, when I try to write a new feature service I get an error: User folder does not exist. I have copied the folder name from the existing folder names that the writer shows. How do I write a new feature service to AGOL using FME?
Thanks
