I can't seem to read layer descriptions from DWG files. I have tried different versions of FME, different reader settings and different DWG types with the same result.
It does seem to read a few of the layer descriptions but I have no idea why it would differentiate them as they seem identical when I open the files in AutoCAD.
Has anyone had the same issue?
Thanks!
