SQLite VACUUM command after writing to db file
  • October 17, 2019
  • 54 views
I was wondering if anyone might be able to help me out? I'm writing tabular data to a SQLite database and I'd like to run the VACUUM command after it's been written. I thought it might exist in the SQLITE3 writer parameters but no luck. I'm using FME 2019 desktop
Best answer by erik_jan
The SQLite writer has the option to run a SQL command after the data is written.
See this SQLite writer parameters documentation for more info.
erik_jan
Forum|alt.badge.img+17
  • October 17, 2019
