I have a simple workspace that I published to FME Server Jobsubmitter: it reads a textfile from a shared UNC path and logs each line. I have configured a specific user FME_Server_User that starts my serverjobs. If I log in as FME_Server to the server, I can access the specified folder and file and modify it or whatever. I can also run the workbench in FME Desktop without a problem. As soon as I start the job from FME Server Repository GUI, it fails.
I get following error:
Text File Reader: Source dataset '\\\\shared\\test.txt' does not exist
A fatal error has occurred. Check the logfile above for details.
The problem occures in a newly created folder on the share. The old folders still work just fine with the same setup (FME_Server_User etc.).
Thank you very much for your help!
