Compare two polyline datasets and remove lines that don't intersect
  • February 27, 2017
  • 110 views
I have two polyline datasets for rivers and streams. Dataset A and Dataset B. Dataset A is very old and the line work is not spatially accurate. Dataset B was created using more accurate methods.
I wish to compare Dataset A with Dataset B, keeping only the lines in Dataset B that intersect or are located near Dataset A. I do not wish to merge the attributes. I have tried nearest neighbor, but that merges the attributes. I have tried line on line overlay and intersector, but that doesn't appear to do what I want either (unless I am doing something wrong). The datasets do share a common attribute field (NAME), but due to the existence of duplicate names of streams within the data, matching by list does not work.
Any help would be appreciated.
  • February 27, 2017
Maybe try using the NeighborFinder with a group-by on NAME and setting a reasonable search radius?
erik_jan
Forum|alt.badge.img+18
  • February 27, 2017
I would try using the SpatialFilter transformer. First you could buffer dataset A to find "close by" features in dataset B.
