Transformer for Google Drive public URL
I am using a Google Drive transformer for my project, but I was considering to make the URL I use to connect to my spreadsheet, public. So, there is no need to provide my credentials or any other person credentials in the process. Is it possible to do that?
Best answer by hollyatsafe
Hi @diogosanto,
If you are uploading a file using the GoogleDriveConnector this will output a Shareable Link attribute.
This URL is equivalent to if you were to using the sharing options directly within Google Drive. By default the URL will be accessible to anyone who has access to the Folder it is written into. For example if the specified folder is restricted to those within your organisation, so will the file be and log in is required to access the link.
Therefore in order to make the URL to the spreadsheet public you'll need to be writing to a Folder that you have shared publicly within Google Drive (Anyone on the internet with this link can view) then you should be able to share the link with anyone.
itay
Forum|alt.badge.img+17
  • June 17, 2020
To do that within FME? I dont know if it is possible.
You can always change it to public via Google Drive.
Hope this helps.
  • June 17, 2020
Hi @diogosanto,
