Hi There,
As per the title, I am having trouble connecting to an ArcSDE geodatabase using a connection file. I can confirm that I am able to connect to the database in ArcMap/ArcCatalog so my feeling is that there is nothing wrong with the connection file, but possibly some other issue that I am having trouble trying to resolve.
I am running FME 2018.1 32-bit and have also tested this in FME 2017.1 32-bit to no avail. I can also confirm that I also have the 32-bit Oracle Instant Client (12.2) installed and configured correctly. I am currently running Windows 7, but I have also tested on a colleagues computer (32bit FME 2018.1 and 32 bit Instant Client) who is running Windows 10, and we both receive exactly the same error.
The error that I am receiving is the following:
Fetching Feature Types Error
<b>Failed to retrieve feature types.</b><p>Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147216072'. The error message from ArcObjects is: {Underlying DBMS error[Unknown errorNo extended error.]}
Close
---------------------------Looking at the full log, I see the following (note I have masked the connection details for security reasons - as mentioned I'm quite confident they are correct since I can access the geodb via ArcMap/Catalog):
Creating reader for format: Esri Geodatabase (ArcSDE Geodb)
Trying to find a DYNAMIC plugin for reader named `GEODATABASE_SDE'
Loaded module 'GEODATABASE_SDE' from file 'C:\apps\FME 2018.1 32bit\GEODATABASE9.dll'
FME API version of module 'GEODATABASE_SDE' matches current internal version (3.8 20180604)
Opening the Geodatabase reader
The ArcObjects license 'Standard' is being selected from the Windows registry
FME has checked out an Esri license. The product checked out is 'Standard'
Installed ArcGIS version is '10.5'
Please ensure the connection parameters are correct (server=`####', instance=`####', user=`####', password=`***', database=`', version=`SDE.DEFAULT')
Failed to obtain any schemas from reader 'GEODATABASE_SDE' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
Failed to obtain any schemas from reader 'GEODATABASE_SDE' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more informationI found a post on Safe Knowledge with the same error (https://knowledge.safe.com/questions/65184/sde-connection-files-fail-following-an-upgrade-of.html) but unfortunately the solution described does not seem to apply to our situation (we did not upgrade - we have a fresh install of 10.5 and the 'ArcGIS Desktop Background Geoprocessing v.10.4' package is not on our machines).
The error is so generic that it is difficult for me to try and solve. I have looked at various forum posts relating to issue '-2147216072' and it appears that there is a whole bunch of different causes and solutions most of which do not relate to my situation.
In order to connect to the database/SDE we are required to be on a internal corporate VPN. My feeling is that the VPN could be the problem - perhaps the ArcSDE reader does not correctly tunnel requests through the VPN, but this is just a best guess (I'm not a network guy so I don't even know if what I said makes sense).
I have tested out this theory by attempting to connect to the SDE in FME while both connected to the VPN as well as disconnected. The error that I receive is exactly the same, I guess I was expecting a more of a connection/network related error when disconnected from the VPN. Unfortunately I have no means to get directly on the network to test out this theory (corporate lyf).
I am honestly stumped, so I would appreciate any help that anyone could offer.
Thanks in advance!
Cheers,
Jamie.
