Text Justification from Oracle Spatial to GDB
  • December 3, 2016
  • 18 views
I have to migrate text data from Oracle Spatial in to GDB and place a Point at center of Label. I tried doing that by LabelPointReplacer, Coordinate Extractor, Rotator, BoundingBox and CentrePointReplacer Transformers. But the justification of the Text has not come out properly. I mapped the oracle justification values in geodb_v_align and geodb_h_align. BUt justification of text is not being read properly in FME. I have migrated the Annotation in a seperate FeatureClass. The Text is aligned correctly in ArcMAP as per its justification values. But when i read this featureclass in FME to extract its central point, justification again creates a problem. Any solution ??
Forum|alt.badge.img+62
Unfortunately Oracle is not mentioned in this article, but maybe it's useful:
Text Justification
  • December 5, 2016
Text Justification
I have sen this post, it says, Data Inspector does not attempt to show justified text. I have mapped the geodb_v_align & geodb_h_align from this article only. Still no success...
