Can I retain unmatched features using Joiner 1:M
  • March 10, 2014
  • 11 views
inframan
FME newbie here,
I'm joining taxroll (dbf) data with (shp) parcel data. I'm creating stacked parcels where the parcel number is repeated in the taxroll using a 1 to many join. It works great but I am losing the parcels with a non matching or null parcel numbers. Is there a way to retain the 1:0 polygons and also create 1:M polygons at the same time?
thanks
  • March 10, 2014
The Joiner (1 : M) doesn't retain unmatched features. Consider using the FeatureMerger (Process Duplicate Support: Yes) + ListExploder, or the InlineQuerier with appropriate SQL query.
Takashi
  • March 11, 2014
for example,
FeatureMerger + ListExploder:
InlineQuerier:
inframan
  • March 13, 2014
works great, thanks
