I had a column in postgresSQL which was serial. The column was generated by postgresSQL so I didn't have to input it. After transferring it from serial to integer, I found I couldn't write it to database in FME workspace, which may have already cached previous database information. I inspected the data and figured that all the values of this column were transferred to null when writing to database. To solve it, I deleted the column and recreated it with same name in DB. Then everything works. Is this a bug of FME? By the way I am using 2018.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
