I have a Microstation DGN file, and inside it is an imported raster (not a referenced raster file). In FME this raster image is coming through as a nongeometric collection. How Do I go about extracting the raster file from the DGN so I can use it as a raster image? I have tried using the geometry filter, but since fme reads the raster as a nongeometric collection it thinks there is no geometry instead of filtering it through the raster port. Are there certain attributes that need to be set on the raster image in Microstation in order for fme to register it as a raster?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
