I'm using Geodatabase_SDE reader and writer with different connection files.
I have one database "Operations" with user1 and another database "Data_Sources" with user2. They both support geometric data used in ArcGIS. I try to read from Operations.user1.featureclass1, and write to Data_Sources.user2.featureclass2.
Operations.user1.featureclass1 is in a dataset "ops". I'm tryng to just write a standalone featureclass in Data_Sources, so i am leaving the Feature Dataset parameter as blank. However, seems that no matter what i try, the error keeps getting thrown that I can't do the operation because I'm not the database owner. And the log says it was trying to write Data_Sources.user2.featureclass2 to the Operations.Ops dataset.
The message is:
Geodatabase Writer: Creating feature class `User2.Featureclass2' in feature dataset 'Operations.User1.Ops'
An error occurred while attempting to create the feature class 'User2.Featureclass2'. The error number from ArcObjects is: '-2147220969'. The error message from ArcObjects is: {Must be the owner to perform this operation.}
Why does this writer keep trying to write to a dataset when I am trying to tell it not to?
