GITHUB API: Posting an issue to private repository: 404 error
  • November 6, 2019
  • 32 views
HI there,
Just wondering if anyone has any experience interacting with the GitHub API on FME.
I'm trying to use an http caller to post a new issue to a Private repository, but get a 404 response body.
Get requests are fine with the authorisation headers i'm using:
Authorization: Bearer <my token>
Am I missing something obvious?
Thanks in advance,
laurawatsafe
Forum|alt.badge.img+11
Hi @alexburnett,
I've done a bit of work using the GitHub API with FME. I ran a quick test using the HTTPCaller to confirm if I could use a POST request to create a new issue on a private repository and was able to do so successfully. Just to double check, what Request URL did you have configured within the HTTPCaller? The 404 error message would typically indicate a problem with the URL itself, so just wanted to rule that out as a possible reason for the error you are seeing.
In case it helps, here are the settings that I used when I tested this:
