textvalues of an excelfile gets an extra apostrofe when it is written to another excelfile.
  • May 22, 2014
  • 24 views
If i let FME copy excelfile A to excelfile B the textvalues of excelfile A gets an extra apostrofe when it is written to excelfile B.  So value xxxx from excelfile A becomes 'xxxx in excelfile B. Does anyone know how to prevent this?
  • May 23, 2014
I was not able to reproduce this using FME 2014 SP1 and the XLSX reader/writer.
Which version of FME are you using?
David
  • May 23, 2014
Hi David,
Thanks for your reply. I am usine FME 2011.
Kees
gio
Forum|alt.badge.img+15
  • May 23, 2014
This is indeed an old problem in prior excellwriter.
In the old days ...; ) 2011 we had to, like clean it up in excell itself.
  • May 23, 2014
Gio is spot on, you really should upgrade to at least FME 2013 SP4.
The Excel reader/writer was completely rewritten in FME 2013 SP2 and it was a huge improvement.
There are also a lot of other very compelling reasons to upgrade, so highly recommended.
David
