Connecting to Cisco CMX
  • April 16, 2019
  • 26 views
magnus
Participant
Hi
I am trying to retrieve JSON location data from a CMX service. If I login using Chrome, I can access a JSON document from .../api/location/v2/clients and use that file as input in a workspace, but I would like to integrate the authentication process as well in the workspace. Any hints on how to achive this using the HTTPCaller?
The documentation can be found at https://www.cisco.com/c/en/us/td/docs/wireless/mse/10-2/api/b_cg_CMX_REST_API_Getting_Started_Guide/b_cg_CMX_REST_API_Getting_Started_Guide_chapter_01.html.
Magnus
magnus
Participant
  • Participant
  • April 16, 2019
Solved it, had to change the SSL option.
