Getting error while connecting to ArcGIS Online Feature service reader
  • August 31, 2018
  • 66 views
Hello
I am getting this error when I try to connect to ArcGIS online feature reader.
Can anyone help with this?
Thanks
Nikki
Error: Connect to www.arcgis.com:443 [www.arcgis.com/18.234.22.25, www.arcgis.com/54.236.87.106, www.arcgis.com/18.234.22.29] failed: Connection refused: connect
Error: COM.safe.fmewebservices.FMEWebServiceException: Connect to www.arcgis.com:443 [www.arcgis.com/18.234.22.25, www.arcgis.com/54.236.87.106, www.arcgis.com/18.234.22.29] failed: Connection refused: connect
at COM.safe.fmewebservices.FMEHttpUtils.post(FMEHttpUtils.java:162)
nathanatsafe
Forum|alt.badge.img+9
  • September 11, 2018
Hi @nikkia, thanks for your question.
Can I ask what version of FME you are using? Do you see the error when running the translation? Or when trying to pick a Feature Service? Are you able to connect to ArcGIS Online in your browser?
Thanks,
Nathan
  • February 10, 2020
Have anyone solved this issue, because we are facing same issue. When the workbench is running from FEM Desktop its running successfully, but after publishing workbench to FME server its throwing the same error
siennaatsafe
Forum|alt.badge.img+12
Hi @rakeshent,
What version of FME Server are you using? Does your FME Server use a proxy? Can you follow the steps in the first comment here and let me know what happens? https://knowledge.safe.com/questions/88927/how-do-i-reliably-connect-fme-server-201819-to-arc.html
