how to import ArcGIS online image data into FME Data Inspector
  • July 31, 2017
  • 31 views
13gamat
Participant
Forum|alt.badge.img+3
trentatsafe
Hello @13gamat,
The ArcGIS Online images, are they attachments related to a feature?
If so, FME 2017.1, which can be found here: https://www.safe.com/support/support-resources/fme-downloads allows you to read in Attachments. This can be done adding the feature class to the workspace. Once the feature class is on the workspace, open up the parameters and set 'Include Attachments' to 'Yes'. This will read in the features along with their attachments.
If the images are not attachments, could you please provide some more information.
rylanatsafe
Forum|alt.badge.img+14
  • August 3, 2017
Hello @13gamat,
FME 2017.1 has been released and is no longer in beta.
safe.com/downloads
