Get the number of different values in a list
  • February 5, 2015
  • 123 views
Hi!
I have a list attribute such this one:
['a', 'b', 'c', 'a', 'b']
I would like to have the number of different values present in that list.
In python I would do:
 list=['a', 'b', 'c', 'a', 'b'] len(set(list)) >>> 3
 Is it possible to get that count with some fme transformer?
Best answer by gio
Just use ListDuplicateRemover and than ListElementCounter. (if it is a valid list to fme that is)
gio
Forum|alt.badge.img+15
  • February 5, 2015
  • February 6, 2015
Alternatively, if you don't want to modify the original list, use the ListHistogrammer instead and then count the number of elements of the resulting "_histogram" list with the ListElementCounter.
I think your Python solution is elegant and efficient.
# Script Example for PythonCaller
def countUniqueElements(feature):
    feature.setAttribute('_count', len(set(feature.getAttribute('_list{}'))))
Takashi
