Move a .zip file from one location to another?
  • February 27, 2018
  • 83 views
mbuske
I have a collection of .zip files (ie. AB_170203, BC_180203) that I would like to move from one drive to another for archiving purposes. I have a tester set up to separate the .zip based on date and now I just need the .zip's to move.
Writer Parameters
File Operation:MOVE
Copy Source Folder: No
Copy Subfolders: Yes
The process will complete but nothing moves.
Best answer by david_r
For the FILECOPY writer, you'll have to specify the following three parameters for each incoming feature:
filecopy_source_datasetContains the source filename (wildcards are supported)filecopy_dest_datasetContains the target directoryfilecopy_dest_filenameContains the target filename. Empty = preserve source filename
More info here:
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/filecopy/Feature_Representation.htm
  • February 27, 2018
More info here:
hi. am facing a smiliar issue. is this resolved? . if yes share the solution please
i have added nul in value for filecopy_dest_filename but still the file is not deleted
