Hello. I created a user parameter to select the separator in the CSV reader. I linked the user parameter to the separator field in the CSV reader and it works. But I do not know how to write TAB as a separator into user parameter. I tried \\t, ^I, <control>, <u0009> and so on. Can someone tell me?
TAB in User Parameter
Best answer by takashi
Hi @lukas108, if you created the user parameter from the reader parameter "Delimiter Character" on the Navigator window, you just can select "tab".
Creating a new user parameter linked to the Delimiter Character parameter on the Navigator
Selecting an appropriate delimiter through the parameter
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
