I have an issue with using the Dynamic writer in FME Server 2013. It produces the zip file but its empty and the location is has written to on disc is also empty. When running the workbench it works but not when uploaded to server 2013.
I had no issue with the dynamic writer on 2012, is there a setting that i have missed out? Even the standard ''easytranslator'' does not produce and files so something to do wth the writer rather then the individual workbench
Regards
