I've gor an ascii raster that I want to convert to a xyz file.
This should not be to difficult now should it?!
I get this errorr: POINTCLOUDXYZ writer: Failed to obtain point cloud from feature.  Only features with point cloud geometry are expected
You have to transform the raster into a point cloud before writing. Try using the PointCloudCombiner transformer to do that.
Takashi
