Datadownload service not sending file geodatabase
  • November 6, 2013
  • 12 views
Dear All ,
We are using datadownload service to extract data and sending it by email , output files excel and filegeodatabase , excel is zipped and sent by email , but file geodatabase is creaetd on the server but not zipped , that is why email is not contained the file geodatabase , is there is any reason for that.
Thanks ,
fmelizard
Forum|alt.badge.img+21
  • November 6, 2013
How are you creating  the email? And referencing the attachments?
  • November 7, 2013
Users are entered it from he datadownload service page , when we use personel database it is wokring fine but not with file geodatbase , we did not receive file geodatabase by email.
  • November 7, 2013
Hi Khalid,
When pubishing your workspace to FME Server, each service has an Edit button for setting the Service Properties. Here you can select the "Desired Output Writer". Make sure the GDB-writer is selected.
Thomas
  • November 7, 2013
Thanks everyone and special thanks to TG for getting me the right answer
