How to read SQL stored procedure in FME?
  • February 9, 2016
  • 125 views
I need to read stored procedure from SQL instead of each table. Please assist. Thanks.
  • February 9, 2016
I am using Microsoft SQL Server Non-spatial database.
  • February 9, 2016
Hi, I think you can execute a Transact-SQL EXEC statement with the SQLCreator or SQLExecutor.
erik_jan
Forum|alt.badge.img+26
  • February 9, 2016
If you mean a stored function (a stored procedure does not return data) you can use the SQLCreator to execute a SQL statement and use that transformer to read data into your workspace.
