Mapping multiple features with a single one, in INSPIRE compliant GML
  • September 13, 2017
  • 17 views
I am in the process of tranforming an access file to a GML file. In the FME workspace i use a database joiner transformer, so as to join two tables in the MS Access. These two tables have a One-to-many relationship and i select the option to create a new feature for each much.
The target attribute in the GML writer has the following format: groupedInstallation{}.xlink_href. When i try to much the produced attribute (after the join) with this one, the matching is not possible.
When i define the target attribute as follows: groupedInstallation{0}.xlink_href (with a 0 between the brackets) the matching in the GML is achieved only for one record of the attribute of the reader.
Could you please let me know how i can match all the records of the attribute to the GML writer ?
Thank you in advance,
With best regards,
Valantis
@NatalieAtSafe
Best answer by erik_jan
Have a look at the FeatureMerger transformer.
Use the many (of the 1:n) as Requestor and the one (1:n) as Supplier.
The Merged output will have all Requestors with the Supplier information merged to it.
erik_jan
Forum|alt.badge.img+26
