Reprojecting attribute values (no geometry)
Dear FME community,
I have a comma separeted file (CSV) which contains coordinates of polygons. They are in the form:
4606782.08077,5649438.11392,4607573.11623,5649937.71526
4607494.19448,5649114.04178,4608310.37980,5649629.52724
4625760.04745,5648557.21385,4626429.36498,5648979.94071
They are in the German coordinate system EPSG:31468 and should be transformed to EPSG:25833. How can I easliy reproject these values and write them out as a new CSV file? Do I have to build polygons first, transform them and then extract the geometry again, or is there a more easy way to do it?
Kind regards
Thomas
Best answer by pratap
AttributeReprojector will Reprojects attributes from one coordinate system to another. Hope this helps
Pratap
pratap
Forum|alt.badge.img+11
  • May 3, 2016
Pratap
  • May 3, 2016
pratap wrote:
Pratap
Wonderfull! With 2 AttributeReprojectors it works (for the 4 coordinates values). Many thanks.
