Anyone else seeing differences in PointConnector between FME 2012 and FME 2013?
I have a workbench that works perfect in FME 2012 SP4 but when I run the same one in FME 2013 SP1 (and 2014 beta), the number of features that are created are different. I have narrowed it down to the PointConnector and the way it is handling lists. I set the connection break to the parent_id field (which is the same for all of them) and set the list name to origSeq. Now in 2012, the point are connected and the original attributes that were present on the points are stored in the list as origSeq{0}. I then add a ListIndexer and set to 0 then remove the list and now the lines have the original attributes from the points. In 2013, the last point to get processed has its original attribute shifted to the index of 1.
Anyone else seeing wierd behavior with the point connector?
I wanted to send this to the community before I send to Safe support.
Thanks,
Sean
Forum|alt.badge.img+19
  • July 26, 2013
Hi Sean,
In my test with a simple workspace, I couldn't reproduce such a behavior. Could you find any differences between your workspace and mine?
Takashi
  • July 26, 2013
P.S. My environment is FME 2013 SP2 Build 13499.
