Attribute's encoding check ?
  • November 12, 2015
  • 15 replies
  • 106 views
Hey,
I need to control the string encoding (utf-8) but i didn't find a transformer for.
Do you have a tip to test the encoding ?
Thanks for your help.
Alexy
pratap
Forum|alt.badge.img+12
  • November 12, 2015
Is it possible to explain further more
Pratap
  • November 12, 2015
Of course,
I need to make sure that the attribute type is "string" and check its encoding to utf-8.
I can not find transformers to perform these actions.
Thanks in advance
  • November 12, 2015
If you will change the type of attribute(s) to utf-8 unconditionally, the AttributeEncoder might help you.
However, there isn't a transformer to check if the type is "string". If you have to check that, consider using a Python script (PythonCaller). The "FMEFeature.getAttributeType" method returns an integer identifier indicating the internal attribute type of specified attribute.
Takashi
  • November 12, 2015
Hi
If you need to know if a particular attribute is unicode or not, you can do the following in a PythonCaller:
import fme
import fmeobjects
def FeatureProcessor(feature):
    s = feature.getAttribute('MyString') # Change attribute name as needed
    if isinstance(s, str):
        print "ordinary string"
    elif isinstance(s, unicode):
        print "unicode string"
    else:
        print "not a string"
David
  • November 12, 2015
Hi
import fme
import fmeobjects
    else:
David
@david_r, aside, how did you paste the script into the code block? I tried a few times in other Q&A;, but the script will not be contained in the code block correctly anyway. See here. I gave up and reported it to Safe...
https://knowledge.safe.com/questions/19701/point-to-line-to-point-retain-original-attributes.html#answer-19789
  • November 12, 2015
Yeah, that code block thingy isn't very good... Basically, you can't have any blank lines, or it'll mess it up.
  • November 12, 2015
I found a workaround for the blank lines. You can toggle into HTML tag mode when editing your post and replace the blank lines with a <br> tag. Then you get two blank lines for the price of one ;-)
  • November 12, 2015
Great, thanks. I'll try it at the next chance. Hope the editor will be fixed as soon as possible. @mitahajirakar, @dewetvannieker
  • November 12, 2015
Takashi
Tank you.
Takashi, do you know if a grid of interpretation of "feature.getAttributeType"'s result is available somewhere?
  • November 12, 2015
Tank you.
You can find required information in the API reference. Go to:
Knowledge Center home > FME Documentation > Python FME Objects API Reference
  • November 12, 2015
Link for the lazy: getAttributeType
But as you can tell, it won't help telling the difference between a unicode or a regular string. You will have to use the Python code below for that.
  • November 13, 2015
Thanks for the link for lazy :-)
I thought that FME_ATTR_STRING (=11) returned by the getAttributeType indicates "string". Was I wrong?
  • November 13, 2015
@takashi, you're right about FME_ATTR_STRING, of course. My point was that it won't tell you if the attribute is a string encoded to the current locale (e.g. cp1252 here in western Europe) or if it is in unicode (utf-8 or utf-16).
  • November 14, 2015
@david_r, thanks for the clarification. Yes, of course it's necessary to add some codes to check the encoding.
  • November 14, 2015
@mitahajirakar, thanks for your efforts. Regards.
