Hi guys, I am still learning FME and have made a few workspaces which are working well for me however I am doing a merge with a SQL non spatial and a mapinfo tab file and am trying to make an end result of the poly's having no fill or patterns, just an outline and being transparent. I have tried many things, the closest I have gotten is creating the attribute mapinfo brush transparent and setting to True, and if I create a pattern with Mapinfo styler the transparency works - obviously with the pattern though, I have tried doing an attribute expose and remove for the mapinfo_brush_background and foreground. Sorry I have been trying to do this for a couple of hours and tried all sorts of combos but just can't get it.
Thanks in advance
Garry
sorry found it on this link
https://safe.secure.force.com/AnswersQuestionDetail?id=906a0000000cj3TAAQ
brushpattern needs to be 0.
Thanks
mapinfo_brush_transparent = TRUE worked for me
