Having trouble with the Attribute Pivoter
  • November 27, 2018
  • 108 views
stefanh
Forum|alt.badge.img+8
I have the following table.
labelareacodecountA100114A10023A10032A10188A10291B100164B10022B10041B101268B102121C100137C10024C10042C101493C10217
I want to pivot the table. So I get the following result.
RijlabelsABC1018826849310291121171001146437100232410032
1004
12
I tried the AttributePivoter (and also the AttributeTransposer) but I can't get this to work. I don't understand what I am doing wrong.
Hope someone can help me with this issue!
Thanks!
Forum|alt.badge.img+35
  • November 27, 2018
I normally pivot data by using the Attribute Values to create new attributes
Pivot_attributes.fmwt
stefanh
  • November 29, 2018
Thanks! This works.
philippeb
Forum|alt.badge.img+20
  • March 24, 2020
Would that be possible to put once again online the fmwt? Thanks!
daraghatsafe
Hi @philippeb
I don't have the exact workspace that you are looking for but here is a post that may help with your question.
https://knowledge.safe.com/articles/31702/pivot-table-using-fme.html
Also as this post is over 3 years old it may be best to post a new question if you are still stuck.
