Using a calculation in another field
  • August 15, 2019
  • 140 views
I have a set of data, with dates ranging from 2005 to 2019. I use the interval feature in the Date Time Calculator, and am able to calculate the interval between the two dates (14 years).
In another table, I have a number of jobs grouped, and I want to use the 14 years calculation to determine the number of jobs per year. (silly example given below)
Fruit
Total Fruit
Fruit per year (ie, total / 14)
Apples
20
1.43
Bananas
30
2.14
Cherries
40
2.85
So I want to get the "Total Fruit" and divide it by my _results_interval. But it wont work. I try to use Attribute Manager, and then bring in the _results_interval, but it displays it as a new row. And wont let me bring it into the arithmetic calculator either.
Forum|alt.badge.img+62
It should work. The _results_interval will be present as a new row on all features and you should be able to use it in the Arithmetic editor. Can you share a screenshot of how you've set up your AttributeManager?
  • August 15, 2019
I solved it. I used feature Merger. Its clunkly, but works.
Couldn't get the Attribute Manager to work for the life of me.
Forum|alt.badge.img+46
  • August 15, 2019
If the attributes you need for the calculation are in two different tables and therefore two different features you cannot perform a calculation with them without joining them in some way. Arithmetic operations operate on a single feature so both values must be present on the same feature to be used in a calculation.
It sounds like you have achieved this with a FeatureMerger
  • August 16, 2019
Yeah, after many attempts and a few swear words, I got there.
