Greetings people,
I need to fill three tables in SQL Server Non-Spatial. Tables are point, line and polygon. I read data from GML. Now, I need to insert all points, points from lines and from polygons, lines and lines from polygons and polygons, but they must fill some condition. All of them have attribute LAYER and GEOMETRY (WKB format). I need to write just these who has minimal value of LAYER (integer) and with distinct GEOMETRY. This minimal value of LAYER is minimal for each group of features with same GEOMETRY. This rule is same for all feature types.
E.g. I have
WKB1, 1
WKB1, 2
WKB2, 2
and only need to write the last two.
Can someone give me an idea? I hope you know what I asked. :D
