Related to my question about importing a prj file, I think one of these might be a solution. My inputs are DGN files and my outputs are shapefiles. The DGN files do not have a projection defined so I thought I can replace the prj file created by the shapefile writer. I came up with two different ways to do this but I don't know what will work in FME. Will one of these work for replacing my prj file?
- create the shapefiles and save in a fanout by a given attribute (category)
- read in the source prj file
- rename the source prj file to match each new shapefile and overwrite the existing prj file, effectively overwriting the one created by feature writer. What transformer will I use for renaming the file and saving it?
- I already have a process for creating the list of shapefile names, will fanout by the same attribute overwrite the existing file?
- replace all of the text in the new shapefile prj file with the text from the source prj file
- this seems the easiest but I don't know how to read in, replace text, and then resave
- create the shapefiles in a feature writer
- merge the source prj with the new shapefile and overwrite the shapefiles
- this concept seems simple but the least likely to work
Any suggestion on what will work and the best transformer for the task?
