How to convert 3ds file to CityGML LOD3?
  • November 26, 2019
  • 80 views
I already have a lot of 3ds files with textures for building.
I'd like generate CityGML LOD3 data from these 3ds files.
For LOD3 data generating, I think the first and the biggest problem is how to classify Window, Door and Wall.
I think it is possible to crop or edit the window or door in 3D MAX.
But I don't know how to assign the properties such as Window, Door and Wall.
If you have any idea or experience, please share your experience.
virtualcitymatt
Forum|alt.badge.img+35
I think you should be able to apply an appearance with a name 'window' or 'door' or wall in 3DMAX - FME can read the appearance names and you could filter based on these?
