An error occurred while attempting to initialize the JAAS login context
  • May 14, 2018
  • 0 replies
  • 373 views
helmoet
Forum|alt.badge.img+8
Hi, we had the following trouble using FME Server:
Could not login using AD user account.
Error log shows first Authenticating user using SASL mechanism "GSSAPI" with KDC address and realm "NL"..., which succeeds. After that an exceptions appears "LDAPException(resultCode=82 (local error), errorMessage='An error occurred while attempting to initialize the JAAS login context for GSSAPI authentication: javax.security.auth.login.LoginException: null (68) caused by KrbException: null (68) caused by KrbException: Identifier doesn't match expected value (906)')", and therefore FME Server concludes "Failed login by user due to insufficient credentials."
It appears to be due to FME Server not supporting Active Directory servers (for reasons of failover we use multiple AD-Servers). Specifying just one of them (in stead of the domain) seems to be a solution to the problem, however, it would be nice if FME Server would support the multiple AD-Servers mechanism.
Any other people recognizing this issue?
