ArcSDEQuerier - bind variables
  • April 11, 2013
  • 27 views
I am using ArcSDEQuerier with only an attribute query to fetch geometry for features.
The where clause uses an attribute value populated by an earlier SQLCreator transformer:
"POLYGON_NUMBER = @Value(POLYGON_NUMBER)".
I have noticed that the query running in Oracle uses a hard-coded value rather than a bind variable.  This adversely affects performance.
Is there any reason why the ArcSDEQuerier does not use bind variables?
Also is there way to alter the SDE connection CURSOR_SHARING session parameter before running the translation so that I can force the use of bind variables?
I am using FME 2012 desktop, the Oracle version is 10g and ArcSDE version is 9.3.
Best answer by david_r
for what it's worth, the SQLExecutor doesn't bind variables either, so I guess it's by design.
Which is a pity, both because of performance but it also makes it a little more complicated when you want to pass string values that contain quotes (Oracle specific solution here).
David
  • April 11, 2013
David
