However when I try to do the same with an ESRI GEODATABASE_SDE it logs that the features are written - however there is nothing in the database (also not in any other features or tables on the same server). Doesn`t the ESRI GEODATABASE_SDE writer handle the fme_db_operation parameter the same way as the SDE30 writer?
Any other tricks to be aware of when working with writing to ArcSDE?
