HTML Report Generator Color object based on attribute
  • October 4, 2017
  • 105 views
stefanh
Forum|alt.badge.img+8
How can I give objects a color based on attribute value in an HTML-page generated with the HTML report generator. So I want an object to be 'red' when value is '1' and to be 'yellow' when the value is '2'.
I tried using the FeatureColorSetter, but this does not seem to work.
There is an ArcGIS Feature Layer available. I can add this to the Map (ESRI Leafet) option. However the colors are not visible in the map, because they are 'overlayed' by the layer color set in the HTML Report Generator
Is there a way to not set the layer color; this option is obliged. I do not know how to avoid this.
Best answer by annabelleatsafe
Hi @stefanh,
This is a feature we are currently working on supporting in future releases of FME. Currently there is no way to set the layer color based on an attribute, and this is being investigated as PR#74806. In regards to setting a layer to transparent, this is a second PR that I have filed on your behalf, PR#79757. We will follow up on this post when there is a fix or update to these PRs. My sincere apologies that you have run into this issue.
Hi @stefanh,
stefanh
  • October 10, 2017
Hi @stefanh,
Thanks for the reply and good to hear that you are working on the feature.
For now I used the 'Custom HTML' option in the HTML Report Generator. In the 'custom HTML' I created an HTML with an Leaflet viewer and the ArcGIS Feature Layer. This works perfect.
gio
Forum|alt.badge.img+15
  • October 10, 2017
@stefanh
Use an conditional attribute creator and set this to the relevant attributes.
stefanh
  • October 11, 2017
@stefanh
@gio
Thanks for the reply. However I was referring to a map, but it is good to know that it is working with a table.
