Group processing by objects count and parallelize treatment
  • June 13, 2025
  • 82 views
geo-x
Dear FME Community,
I should to optimize my job, and for that I need to make group processing with an optimization of objects numbers like that :
And after, as you can see, make a parallelize of objets for not having only a linear treatment.
Do you know how can I do this ?
Thank you very much.
Best answer by takashi
You can create a custom transformer and set transtormer parameters - Group By and Parallel Processing to implement paralell processing. See these pages to learm more.
Custom Transformers and Parallel Processing
Parallel Processing in FME
However, I cannot understand why 24 objects (4 groups, 6+3+4+11; left side of your screenshot) should become 27 objects (3 groups, 6+10+11; right side) after perfoeming "Group 10 objects" (center). Could you please explain how the "Group 10 objects" should work?
  • June 13, 2025
geo-x
  • June 16, 2025
Dear ​@takashi,
Thank you for your help. This post is the suit of this post :
who works, but I’ve a problem with “Insufficient memory available”
(My PC configuration is :
Processor    Intel(R) Xeon(R) Platinum 8375C CPU @ 2.90GHz   2.90 GHz
Installed RAM    64.0 GB (63.0 GB usable)
Storage 750 Go
System type    64-bit operating system, x64-based processor)
So I try to optimize my workbench with a group and parallel processing.
For the number of objects in a gorup, sorry, you’re right, this was a mistake I have corrected the picture.
So, I would like the process, optimize the groups of objects of 10 maximum and if a group is composed of about 11 objects, he take it in one group only.
I’m go to reading articles which you shared.
