Get snapping tolerance of a Microstation file v.8
  • November 6, 2019
  • 0 replies
  • 9 views
I am reading a Microstation v.8 des file from FME. The file contains lines and I am trying to generate polygons with AreaBuilder. Sometimes I can't generate the areas since the lines don't touch. I think it is a snapping problem.
How can I get the snapping tolerance defined in the Microstation v.8 file that I am reading in FME?
Thank you.
