Creating geometry from GeoJSON text
  • April 25, 2025
  • 7 replies
  • 138 views
mattebridges
Hi - I’m trying to create polygon geometry from the GeoJSON in the attached file. This is a string attribute returned from an API.
I was thinking I could use a GeometryReplacer with the encoding set to GeoJSON. However when I do this the record is rejected with an ‘INVALID_PARAMETER_GEOMETRY_SOURCE’  message.
I have passed the GeoJSON attribute through a JSONValidator and this doesn’t flag up any issues.
Any suggestions for what I’m doing wrong, or alternative approaches would be very welcome.
Thanks in advance.
nielsgerrits
Forum|alt.badge.img+64
What version FME do you use? When I read it as text and use a GeometryReplacer in 2024.2 it just works?
jobvdnoort
Forum|alt.badge.img+13
  • April 25, 2025
Hi mattebridges,
I also have a example for you :)
Similar to what Niels is doing he was just a minute quicker….
Edit: apperantly Niels changed his awnser… but I still have a working example for you  haha
mattebridges
  • April 25, 2025
Thanks so much ​@nielsgerrits and ​@jobvdnoort for your suggestions.
We’re on 2023.1 - so nothing ancient.
I’ll have a go with both suggestions now - really appreciate your help here :-)
mattebridges
  • April 25, 2025
Thanks again to @nielsgerrits and ​@jobvdnoort,
I was able to get this to work using serial JSONFragmenters. I’m not sure I understand why the second Fragmenter produces geometry but hey I’ll take it!
​​​​​​​Best wishes.
  • April 25, 2025
Hi ​@mattebridges ,
Originally GeometryReplacer (Geometry Encoding: GeoJSON) only supports replacing a “geometry” object with a geometry, not support replacing full GeoJSON document.
However, GeometryReplacer in FME 2024.2 or heigher supports replacing full GeoJSON document. You can find when the enhancement has been introduced in the Change Log, linked from the FME Downloads page.
Change Log - Result of Search "GeometryReplacer"
danilo_fme
Forum|alt.badge.img+52
  • April 25, 2025
Hi ​@mattebridges ,
Awesome.
mattebridges
  • April 26, 2025
Hello ​@takashi - thank you so much for taking the trouble to explain this.
I’m relieved to know there was a reason why I couldn’t get the GeometryReplacer approach to work.
Best wishes!
