I am having trouble writing a few rasters to a raster fgdb. Most are fine but a generate errors of undefined. But previous definition seems fine. bit of a stumper. don’t think it’s a projection issue. Any thoughts?
Best answer by aliatsafe
Thanks for posting to the community forums!
The File Geodatabase API (FILEGDB) format does not support rasters. We do have a File Geodatabase based writers for Raster Datasets and Mosaic Datasets (these are very different than each other, and possibly may not fit your needs).
Raster Dataset - Giant single rasters that can rasters mosaic-ed into them.
Mosaic Dataset - table consisting of points to rasters stored elsewhere, that can be read as a raster catalog (table/list of rasters) or a large single mosaic-ed one.
These two writers require an ArcGIS install and license to work.
Hope this helps! Let me know if you have any questions.
