Oracle stored function return value
  • November 1, 2017
  • 6 replies
  • 289 views
Hello FME Experts,
I need some help in figuring out how to use a return value from a stored function in oracle.
Stored function:
create or replace FUNCTION TestReturnFunction(inputval in varchar2)
return NUMBER
IS
countnum number:=0;
BEGIN
IF( countnum = 0 ) THEN select count(*) into countnum from TestTable where MyVal is not null and TestID=inputval; END IF; IF( countnum >= 1 ) THEN RETURN (0); ELSE RETURN (1); END IF; END TestReturnFunction;
How I call it:FME_SQL_DELIMITER / declare result1 number; begin result1 := TestReturnFunction('TestThisValue');
end;
While this runs successfully, no value is returned in the "result" section of sqlexecutor. Any help on how to get the output would be greatly appreciated!
Best answer by erik_jan
You can use the SQLExecutor with:
Select TestReturnFunction('TestThisValue') as _return from Dual;
The result will be stored in the attribute _result (which you need to expose).
  • November 1, 2017
Hi, please look at this previous post, hopefully it can help you along:
https://knowledge.safe.com/questions/4782/results-from-oracle-stored-procedure.html
Let me know if anything is unclear.
erik_jan
Forum|alt.badge.img+26
  • November 1, 2017
  • November 1, 2017
Thank you! That worked.
Here is the exact working SQL for any one who stumbles here:
FME_SQL_DELIMITER ;
Select TestReturnFunction('TestThisValue') as return1 from Dual;
  • November 1, 2017
FME_SQL_DELIMITER ;
You can even skip the semicolon stuff:
Select TestReturnFunction('TestThisValue') as return1 from dual
  • November 1, 2017
Thank you for your reply! I had looked at that post previously but mine was a bit different as I couldn't extract the SP into a SQL.
  • November 1, 2017
It's basically the same solution, but just not as reader-friendly as the answer from @erik_jan :-) Glad it worked out for you.
