GENERIC Reader Error: Generate requires an even number of arguments
  • August 25, 2017
  • 5 replies
  • 23 views
I am unable to add generic reader. My requirement is to read multiple files of two formats i.e *.dwg and *.dgn with dynamic schema.
I am able to add simple generic reader with single value like one dwg file.
Thanks in advance.
Getting the following error in translation log.
Generate requires an even number of arguments -- received arguments `C:\Program Files\FME\fmeworker.exe' `GENERATE' `GENERIC' `NULL' `C:\ProgramData\Safe Software\FME Server\resources\data\user\*.dwg' `C:\ProgramData\Safe Software\FME Server\resources\data\user\*.dgn' `C:\Users\username\AppData\Local\Temp\FME_1503658297685_15148.fmw' `+MERGE_SCHEMAS' `YES' `--SourceREAL_FORMAT' `GUESS_FROM_EXTENSION' `LOG_STANDARDOUT' `YES'Program TerminatingTranslation FAILED.
Defining the path in GENERIC Reader as follows:
"C:\ProgramData\Safe Software\FME Server\resources\data\anyfolder\*.dwg" "C:\ProgramData\Safe Software\FME Server\resources\data\anyfolder\*.dgn"
Best answer by danilo_fme
Hi @dheeraj,
I sinulated here in my FME Desktop 2017:
1) in Reader - Dataset - Select Multiple Folders / Files
2) Write the Folder with two Filters:
3) Result:
C:\\Users\\dlima\\Desktop\\Teste_\\*.dgn,C:\\Users\\dlima\\Desktop\\Teste_\\*.dwg
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+52
  • August 25, 2017
Hi @dheeraj,
3) Result:
Thanks,
Danilo
danilo_fme
  • August 25, 2017
Hi @dheeraj, the solution is good to you?
Thanks,
Danilo
danilo_fme
  • August 25, 2017
Hi @dheeraj,
3) Result:
Thanks,
Danilo
Thanks,
Danilo
  • August 28, 2017
Yes, It works for me, Thanks a lot for the help @danilo_inovacao
danilo_fme
  • August 28, 2017
@dheeraj, you are Welcome !
