Hi
I have a simple workbench that converts ASC > XYZ as below:
fme ASC_to_XYZ.fmw --SourceDataset NT26SW.asc --DestDataset NT26SW.xyz
How can I make the workbench deal with a dynamic "SourceDataset" as sometimes I need to pass a gzipped version of the sourcefile. The example below with the ".asc.gz" sourcefile will not work.
fme ASC_to_XYZ.fmw --SourceDataset NT26SW.asc.gz --DestDataset NT26SW.xyz
I am trying to resist re-writing code that pre extracts the "asc.gz" file before passing to FME.
Thanks,
Mike
