Writing AIXM 5.X geometry
  • September 4, 2024
  • 91 views
youssef
Hello guys,
i am a little desperate in my attempt to write data from our oracle spatial database to AIXM gml. I already watched the  Overcoming the Complexities of AIXM with Model Based Data Integration - FME by Safe Software webinar and also read  this artical https://support.safe.com/hc/en-us/articles/25407686750477-AIXM-4-5-and-5-1-Reading-Writing-and-Validation-EU-Airports-Demo. discussing the matter. I even downloaded the demo workspaces to try to figure out why exactly mine is not working but without any result yet.
I will attach my workspace , a log-file of a successful translation and the resulting gml file to this post and i hope that someone can make out the issues.
Dont wonder about the Geometry-Extracter and Geometry-Replacer transformer i use in the workspace, i have already tried it without them and thought they could help, but also with no result.
Thank you guys for reading this and helping me out in advance, it is very much appreciated!
virtualcitymatt
Forum|alt.badge.img+47
oh, seems your fails are not attached. You might need to try again
youssef
  • September 6, 2024
Thank you for bringing that to my attention! I just uploaded the files.
virtualcitymatt
Unfortunately I’m no expert in AIXM and it’s hard for me to know what to look for here.
Can you explain a little of what you’re expecting in your output?
One thing I did see is that you have two Aggregators close to the AIMXBasicMessage and Runway feature types - in these you are choosing to aggregate Attributes only, this will drop any geometry.
The RunwayTimeSlice should have geometry, however, but without knowing the AIXM schema it’s kind of hard to know if it should or not.
One tip I have is in the writer you can turn on pretty printing to help read the XML doc a little more.
