Remove cloud from Sentinel 2
  • June 30, 2024
  • 89 views
mr_fme
Forum|alt.badge.img+9
I'm working with Sentinel-2 images. I would like to know if it's possible to use FME to remove or clip clouds from images. Does anyone have any ideas? Is it possible to use Google Earth Engine (GEE) with FME?
Thank you.
Best answer by hkingsbury
Looking at this - https://github.com/sentinel-hub/sentinel2-cloud-detector
As its python, you’ll be able to install it against FMEs python and call it using a PythonCaller
hkingsbury
Forum|alt.badge.img+67
  • June 30, 2024
